[postgis-users] ERROR: invalid input syntax for integer: "POINT(389 418.12 4420549.100044)"
Nicolas Ribot
nicolas.ribot at gmail.com
Sun Oct 2 06:41:34 PDT 2011
There is a missing comma in geomFromText, between the geometry definition
and the SRID value:
INSERT INTO pol_p (x, y,the_geom) VALUES (0, 0,
GeomFromText('POINT(389418.12 4420549.100044)'*, *-1));
Nicolas
> Hi,
> I am trying to insert geometry information into a point table. But when I
> try to execute following query, I am getting " ERROR: invalid input
syntax
> for integer: "POINT(389418.12 4420549.100044)" " message. I cannot get a
> solution from my searches.
> Is there anyone who has solution to this problem?
> QUERY :
> GeomFromText('POINT(389418.12 4420549.100044)' -1));
> ERROR :
> ERROR: invalid input syntax for integer: "POINT(389418.12
4420549.100044)"
> Here is my table SQL statement :
> CREATE TABLE pol_p
> gid serial NOT NULL,
> the_geom geometry(Point,2097151),
> x double precision DEFAULT 0,
> y double precision DEFAULT 0,
> CONSTRAINT pol_p_pkey PRIMARY KEY (gid )
> WITH (
> OIDS=TRUE
> Best regards...
> Ayhan Tekgul
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111002/f6b032b8/attachment.html>
