[postgis-users] csv table to points and then create line based on same name
Nicolas Ribot nicolas.ribot at gmail.com
Sun Oct 2 13:00:19 PDT 2011
> wow, thank you so much Nicolas, I'm officially impressed, it worked
> perfectly, so easy and direct and efficient, and the command line (asText)
> to see the coordinates of each profile, wow really great, doing this
> manually in arcgis for instance is painful, time-consuming and most of the
> time stupid, I'm really impressed about how this worked. Please find an
> image of the output.
> You guys rock, this forum rocks,
> Thank you again,
Glad it helped you.
Yes, indeed, Postgis is really a powerful GIS tool !
Nicolas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111002/9055cabf/attachment.html>
