[postgis-users] R: RE: Problems adding postgis raster data to db
dany_x at inwind.it
dany_x at inwind.it
Tue Oct 4 09:35:37 PDT 2011
Thank you for the answer. I already created the .sql file with -k 50x50 -I
options.
>----Messaggio originale----
>Da: Pierre.Racine at sbf.ulaval.ca
>Data: 04/10/2011 17.07
>A: "dany_x at inwind.it"<dany_x at inwind.it>, "PostGIS Users Discussion"<postgis-
users at postgis.refractions.net>
>Ogg: RE: [postgis-users] Problems adding postgis raster data to db
>What if you tile the raster using the -k 100x100 -I options of raster2pgsql?
Same problem?
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of dany_x at inwind.it
>> Sent: Tuesday, October 04, 2011 7:30 AM
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] Problems adding postgis raster data to db
>> Hi everyone,
>> i have problems executing the .sql file i created with raster2pgsql to my
>> postgres9.0-postgis2.0 db.
>> The creation of the .sql from a .tiff went trought without a problem, but
when i
>> try the simple command psql -U user -d db -f raster.sql all i receive is
>> addrastercolumn
>> public.tavag.rast srid:32633 pixel_types:{16BUI,16BUI,16BUI} out_db:false
>> regular_blocking:true nodata_values:'{65535,65535,65535}'
scale_x:'0.4999569'
>> scale_y:'-0.49995690000006' blocksize_x:'50' blocksize_y:'50' extent:
POLYGON
>> ((360718.287740393 5106518.39173093,360718.287740393
>> 5108308.73738983,364560.956473793 5108308.73738983,364560.956473793
>> 5106518.39173093,360718.287740393 5106518.39173093))
>> (1 row)
>> (END)
>> with the cursor flashing near the (END).... i've tried waiting 30 and more
>> minutes, but nothing.
>> The .tiff file is 170mb and the .sql 390mb.
>> Any ideas?
>> Thank you,
>> DC
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
