[postgis-users] R: RE: Problems adding postgis raster data to db
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Oct 4 09:39:09 PDT 2011
Even if the cursor is still flashing, did you check if the table was well created?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of dany_x at inwind.it
> Sent: Tuesday, October 04, 2011 12:36 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] R: RE: Problems adding postgis raster data to db
> Thank you for the answer. I already created the .sql file with -k 50x50 -I options.
> >----Messaggio originale----
> >Da: Pierre.Racine at sbf.ulaval.ca
> >Data: 04/10/2011 17.07
> >A: "dany_x at inwind.it"<dany_x at inwind.it>, "PostGIS Users
> >Discussion"<postgis-
> users at postgis.refractions.net>
> >Ogg: RE: [postgis-users] Problems adding postgis raster data to db
> >What if you tile the raster using the -k 100x100 -I options of raster2pgsql?
> Same problem?
> >> [mailto:postgis-users- bounces at postgis.refractions.net] On Behalf Of
> >> dany_x at inwind.it
> >> Sent: Tuesday, October 04, 2011 7:30 AM
> >> To: postgis-users at postgis.refractions.net
> >> Subject: [postgis-users] Problems adding postgis raster data to db
> >> Hi everyone,
> >> i have problems executing the .sql file i created with raster2pgsql
> >> to my
> >> postgres9.0-postgis2.0 db.
> >> The creation of the .sql from a .tiff went trought without a problem,
> >> but
> when i
> >> try the simple command psql -U user -d db -f raster.sql all i receive
> >> is addrastercolumn
> >> public.tavag.rast srid:32633 pixel_types:{16BUI,16BUI,16BUI}
> >> out_db:false regular_blocking:true nodata_values:'{65535,65535,65535}'
> scale_x:'0.4999569'
> >> scale_y:'-0.49995690000006' blocksize_x:'50' blocksize_y:'50' extent:
> POLYGON
> >> ((360718.287740393 5106518.39173093,360718.287740393
> >> 5108308.73738983,364560.956473793
> >> 5106518.39173093,360718.287740393 5106518.39173093))
> >> (1 row)
> >> (END)
> >> with the cursor flashing near the (END).... i've tried waiting 30 and
> >> more minutes, but nothing.
> >> The .tiff file is 170mb and the .sql 390mb.
> >> Any ideas?
> >> Thank you,
> >> DC
> >> _______________________________________________
> >> postgis-users mailing list
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
