[postgis-users] Trouble with shp2pgsql-gui?
Barend Köbben
kobben at itc.nl
Wed Oct 5 00:57:26 PDT 2011
He solution might be simply that somewhere further in the SQL it tries to
find your shape-file and fails. What is the path you provided for the
shape-file...?
Barend
On 05-10-11 04:05, "John Brisbin" <boabinteractive at gmail.com> wrote:
>G'Day all,
>We're in the early stages of familiarising ourselves with the basic
>management tools and procedures, so apologies in advance if this is well
>documented (somewhere?).
>We're running in a Debian (lenny) environment, using pgAdmin3 (1.14.0),
>and have manually installed the shp2pgsql-gui (2.0).
>In attempting to upload a well-formed ESRI shapefile with GCS_WGS_1984
>projection, we get the following messages in the uploader gui:
>Shapefile type: Polygon
>PostGIS type: MULTIPOLYGON[2]
>Failed SQL begins: "SET CLIENT_ENCODING TO UTF8;
>SET STANDARD_CONFORMING_STRINGS TO ON;
>BEGIN;
>CREATE TABLE "public"."ro310_socio-econ" (gid serial,
>"idnum" int2,
>"fid_" varchar(254),
>"aus_" numeric,
>"aus_id" numeric,
>"f_code" varchar(254),
>"bname" varchar(254),
>"bnum" varc"
>Failed in pgui_exec(): could not receive data from server: The system
>cannot find the path specified.
> (0x00000003/3)
>Shapefile import failed.
>It looks like there is a problem with the encoding (why?) and then later
>on there is a problem with the connection to the database (is that right?)
>Looking for any guidance: much appreciated!
>Kind regards,
>JB
>John Brisbin
>Managing Director, BoaB interactive Pty Ltd
>POB 802 Townsville, QLD 4810
>M: 0407 471 565 | P: 07 3103 0574
>Skype: boabjohn | Twitter: @boabjohn
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Faculty of Geo-Information Science and Earth Observation (ITC)
University of Twente
Chamber of Commerce: 501305360000
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
