[postgis-users] How To Load SRTM Files into PostGIS
Paragon Corporation
lr at pcorp.us
Wed Oct 5 10:50:18 PDT 2011
I seriously doubt it, but Bborie or Jorge probably have a better idea.
For one in 2.0 the st_box2d got renamed to box2d so that alone I think would
probably make it not work.
I think also since the serialization changed raster code is assuming the new
serialization.
Thanks,
Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Pierre Racine
> Sent: Wednesday, October 05, 2011 11:04 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] How To Load SRTM Files into PostGIS
> Regina,
> Any chance a build of PostGIS Raster on 2.0 work on PostGIS
> 1.5.3? Any other option to get PostGIS raster to work on 1.5.3?
> Pierre
> > [mailto:postgis-users- bounces at postgis.refractions.net] On
> Behalf Of
> > Pierre Racine
> > Sent: Tuesday, October 04, 2011 1:01 PM
> > To: Puneet Kishor; PostGIS Users Discussion
> > You may want to try what is available at :
> > http://www.kyngchaos.com/software/postgres
> > Otherwise, I think you might be able to compile a 2.0 version and
> > install just the raster component over your PostGIS 1.5.3 without
> > problem. With the shared libraries renaming from one
> version to the other, though, this night not work...
> > Pierre
> > > From: Puneet Kishor [mailto:punk.kish at gmail.com]
> > > Sent: Tuesday, October 04, 2011 12:47 PM
> > > Cc: Pierre Racine
> > > On Oct 4, 2011, at 11:37 AM, Pierre Racine wrote:
> > > > Hi there is a complete tutorial on how to load SRTM
> rasters in PostGIS here:
> > > > http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01
> > > This is great! Thanks. A question follows --
> > > > You load them as true rasters. This implies you have
> PostGIS Raster installed.
> > > It is not clear from http://trac.osgeo.org/postgis/wiki/WKTRaster
> > > whether I can install PostGIS Raster with PostGIS 1.5.3, or if I
> > > have to go the
> > PostGIS 2.0 way.
> > > I already have a working copy of PostgreSQL 9.0.1/PostGIS 1.5.3
> > > installed via MacPorts under /opt/local that I want to
> continue using.
> > > So, I'd like to download only the PostGIS Raster source
> and compile
> > > it against
> > my existing software.
> > > How do I accomplish the above?
> > > Puneet Kishor
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
