[postgis-users] How To Load SRTM Files into PostGIS
Jorge Arévalo
jorge.arevalo at deimos-space.com
Thu Oct 6 02:24:11 PDT 2011
In the current situation, I think PostGIS Raster won't work with PostGIS 1.5.3.
But Puneet, both versions can live in the same system. You can compile
PostGIS 2.0 with raster support, create a new database and enable it
with PostGIS 2.0 including PostGIS Raster. At same time, your existing
database, enabled with PostGIS 1.5.3, should work without problems.
In my Ubuntu box, I use PostGIS 1.5.3 and PostGIS 2.0, if helps.
On Wed, Oct 5, 2011 at 7:50 PM, Paragon Corporation <lr at pcorp.us> wrote:
> I seriously doubt it, but Bborie or Jorge probably have a better idea.
> For one in 2.0 the st_box2d got renamed to box2d so that alone I think would
> probably make it not work.
> I think also since the serialization changed raster code is assuming the new
> serialization.
> Thanks,
> Regina
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>> Behalf Of Pierre Racine
>> Sent: Wednesday, October 05, 2011 11:04 AM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] How To Load SRTM Files into PostGIS
>> Regina,
>> Any chance a build of PostGIS Raster on 2.0 work on PostGIS
>> 1.5.3? Any other option to get PostGIS raster to work on 1.5.3?
>> Pierre
>> > [mailto:postgis-users- bounces at postgis.refractions.net] On
>> Behalf Of
>> > Pierre Racine
>> > Sent: Tuesday, October 04, 2011 1:01 PM
>> > To: Puneet Kishor; PostGIS Users Discussion
>> > You may want to try what is available at :
>> > http://www.kyngchaos.com/software/postgres
>> > Otherwise, I think you might be able to compile a 2.0 version and
>> > install just the raster component over your PostGIS 1.5.3 without
>> > problem. With the shared libraries renaming from one
>> version to the other, though, this night not work...
>> > Pierre
>> > > From: Puneet Kishor [mailto:punk.kish at gmail.com]
>> > > Sent: Tuesday, October 04, 2011 12:47 PM
>> > > Cc: Pierre Racine
>> > > On Oct 4, 2011, at 11:37 AM, Pierre Racine wrote:
>> > > > Hi there is a complete tutorial on how to load SRTM
>> rasters in PostGIS here:
>> > > > http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01
>> > > This is great! Thanks. A question follows --
>> > > > You load them as true rasters. This implies you have
>> PostGIS Raster installed.
>> > > It is not clear from http://trac.osgeo.org/postgis/wiki/WKTRaster
>> > > whether I can install PostGIS Raster with PostGIS 1.5.3, or if I
>> > > have to go the
>> > PostGIS 2.0 way.
>> > > I already have a working copy of PostgreSQL 9.0.1/PostGIS 1.5.3
>> > > installed via MacPorts under /opt/local that I want to
>> continue using.
>> > > So, I'd like to download only the PostGIS Raster source
>> and compile
>> > > it against
>> > my existing software.
>> > > How do I accomplish the above?
>> > > Puneet Kishor
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Jorge Arévalo
Internet & Mobility Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
