[postgis-users] Need Help :How to Install PostGIS Raster
Jorge Arévalo
jorge.arevalo at deimos-space.com
Thu Oct 6 01:18:27 PDT 2011
On Thu, Oct 6, 2011 at 2:55 AM, Wendi Adrian <wendiadriansaga at yahoo.com> wrote:
> Dear all,
> it is great for me to join with you in PostGIS user milist. :)
> I need your advices, maybe some of you have found same problems with me.
> I have installed PostgreSQL v.9.0 and want to install PostGIS v.2.0 which I
> have download from Postgis website. The files was called postgis-2.0.0 SVN.
> This supports PostGIS Raster database based on documentation I found.
> I try to install it, but always find errors which can described as follow ;
> 1) I use command prompt to run makepostgisdb.bat but I adapt environmental
> variables in windows according to parameters.
> 2) when I run it, I get notification "operation aborted...transaction block"
> 3) I rename libiconv-2.dll in Postgresql/8.4/bin folder to any other name.
> This according to article on
> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-configure-postgis-raster-on-windows.
> 4) But when I run makepostgisdb.bat again, I found another errors "can't
> find libiconv-2.dll....please re-install"
> Do anyone can help me with this?
> Thank you.
> Regards,
> Wendi A
> postgis-users mailing list
Hello,
Renaming the dll file was a solution suggested by a Windows XP SP2
user. Are you in the same situation? I didn't need to do that using
Windows 7.
About the execution of the bat file, could you please send us the
output? Did you experiment any other problems following the previous
steps?
I've responded you in the blog post too. But we can keep the question
in the list (it has a wider audience)
Jorge Arévalo
Internet & Mobility Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://geohash.org/ezjqgrgzz0g
