[postgis-users] Problem with correlative ID after using INSERT INTO
Paul Ramsey pramsey at opengeo.org
Thu Oct 6 08:24:42 PDT 2011
You have little-to-no control over the order things are stored in the
database, you have to specify your order in your SELECT queries
instead.
P.
On Thu, Oct 6, 2011 at 5:17 AM, Gery . <gamejihou at hotmail.com> wrote:
> Hello,
> I'm trying to get a table, composed of other two tables, but the correlative ID of one of them changes, it "jumps", this is what happens:
>    id  | name
>    34 | 79-051
>    35 | 79-052
>    52 | 79-076
>   214 | 96-008A
>   215 |     | 96-009
>    36 | 79-053
>    37 | 79-055
> this shape was inserted as follows:
> shp2pgsql -s 4326 -W UTF-8 -g geom -I -D /home/postgres/shp/line/line.shp | psql -U postgres -d mydb
> after checking it in my db, it looks like:
>    34 | 79-051
>    35 | 79-052
>    36 | 79-053
>    37 | 79-055
> this is the part of the code I used to insert this table:
> INSERT INTO both_lines (ID, SURVEY, PROFILE, TYPE, SOURCE, LENGTH_KM, LENGTH_NM, COMMENTS, GEOM)
> SELECT ID, SURVEY, PROFILE, TYPE, SOURCE, LENGTH_KM, LENGTH_NM, COMMENTS, GEOM FROM line;
> I tried adding "ORDER BY ID" at the end of the second line (after "line") but didn't work.
> Any suggestions are very welcome, thanks in advance,
> Gery
> postgis-users mailing list
