[postgis-users] FW: Problem with correlative ID after using INSERT INTO
Gery . gamejihou at hotmail.com
Thu Oct 6 11:41:21 PDT 2011
Thanks Paul, I put ORDER BY ID before Select and after it but didn't work. Could you provide me please an example based on the code below?
INSERT INTO both_lines (ID, SURVEY, PROFILE, TYPE, SOURCE, LENGTH_KM, LENGTH_NM, COMMENTS, GEOM)
SELECT ID, SURVEY, PROFILE, TYPE, SOURCE, LENGTH_KM, LENGTH_NM, COMMENTS, GEOM FROM line;
Thanks,
> From: gamejihou at hotmail.com
> To: postgis-users at postgis.refractions.net
> Subject: Problem with correlative ID after using INSERT INTO
> Date: Thu, 6 Oct 2011 12:17:54 +0000
> Hello,
> I'm trying to get a table, composed of other two tables, but the correlative ID of one of them changes, it "jumps", this is what happens:
>    id  | name
>    34 | 79-051
>    35 | 79-052
>    52 | 79-076
>   214 | 96-008A
>   215 |     | 96-009
>    36 | 79-053
>    37 | 79-055
> this shape was inserted as follows:
> shp2pgsql -s 4326 -W UTF-8 -g geom -I -D /home/postgres/shp/line/line.shp | psql -U postgres -d mydb
> after checking it in my db, it looks like:
>    34 | 79-051
>    35 | 79-052
>    36 | 79-053
>    37 | 79-055
> this is the part of the code I used to insert this table:
> I tried adding "ORDER BY ID" at the end of the second line (after "line") but didn't work.
> Any suggestions are very welcome, thanks in advance,
> Gery
