[postgis-users] Problems with the storage of raster data, raster2pgsql.py -errors
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Oct 7 07:37:06 PDT 2011
Did you check if, even with this error happening, the raster was loaded successfully? I remember having seen this a couple of time but the raster was loaded properly. It might be more like a warning than an error...
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Torsten.Drey at t-systems.com
> Sent: Friday, October 07, 2011 9:34 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Problems with the storage of raster data,
> Hi,
> I'm new to this list and also rather new to the work with PostGIS , I used to work
> with it a couple of years ago and started with it again 2 weeks ago.
> Right now I'm experimenting a little bit with the possibilities to store raster in
> PostGIS. I have a PostGIS 2.0 installation on top of PostgreSQL 9.1 (Running on
> Centos 5.7).
> What I did is to register 8bit and 16bit GeoTiffs inside postgis, i.e. as out-db
> raster. This works absolutely fine and when I publish this data via geoserver
> performance is extremely good!
> When I load and store 8bit data inside postgis everything works well, too. But
> when  I try to load 16bit (the same data which I could register as an out-db
> raster in postgis) data I get an error. The error actually already occurs when I
> generate the SQL-file with raster2pgsql. When I execute:
> python raster2pgsql.py -r dem_pgin  -t public.dem_pgin -s 32632 -k 512x512 -F  -
> I -o dem_pgin.sql
> I get the following error:
> Traceback (most recent call last):
>   File raster2pgsql.py, line 1040, in ?
>     main()
>   File raster2pgsql.py, line 1003, in main
>     gt = wkblify_raster(opts, filename.replace( '\', '/') , i, gt)
>   File raster2pgsql.py, line 945, in wkblify_raster
>     summary = wkblify_raster_level(options, ds, options.overview_level,
> band_range, infile, i)
>   File raster2pgsql.py, line 905, in wkblify_raster_level
>     hexwkb += wkblify_band(options, band, level, xoff, yoff, read_block_size,
> block_size, infile, b)
>   File raster2pgsql.py, line 825, in wkblify_band
>     hexwkb = binascii.hexlify(out_pixels)
> TypeError: non-character (or 8-bit) array cannot be interpreted as character
> buffer
> Is this a general issue with 16bit data or is it maybe an error in raster2pgsql.py
> (From some searching it seems to be numpy issue)?
> Any help is appreciated, Cheers
> Torsten
> T-Systems International GmbH
> Torsten Drey
> Spezialist Geo-Consulting
> GeoServices/GIS
> Vorgebirgsstraße 49
> D-53119 Bonn
> Fon: +49 (0)228 9841 3690
> Fax: +49 (0)228 9841 3990
> E-Mail: torsten.drey at t-systems.com <mailto:rudolf.decker at t-systems.com>
> Internet: http://www.t-systems.com <http://www.t-systems.com>
> Aufsichtsrat: René Obermann (Vorsitzender)
> Geschäftsführung: Reinhard Clemens (Vorsitzender), Dr. Ferri Abolhassan, Olaf
> Heyden, Georg Pepping, Klaus Werner
> Handelsregister: Amtsgericht Frankfurt am Main HRB 55933 Sitz der
> Gesellschaft: Frankfurt am Main
> Notice: This transmittal and/or attachments may be privileged or confidential. If
> you are not the intended recipient, you are hereby notified that you have
> received this transmittal in error; any review, dissemination, or copying is strictly
> prohibited. If you received this transmittal in error, please notify us immediately
> by reply and immediately delete this message and all its attachments. Thank you.
