[postgis-users] ST_Intersect(raster, raster)
Joan wamaithajoan at gmail.com
Thu Oct 13 07:52:16 PDT 2011
Oh really, that would make sense because I have  r7693.
On 13 October 2011 16:44, Bborie Park <bkpark at ucdavis.edu> wrote:
> On Thu, Oct 13, 2011 at 7:27 AM, Joan <wamaithajoan at gmail.com> wrote:
> > Hello,
> > When I run the following query I get the error below. Anyone knows a
> > solution?
> > select ST_Intersects(forest.rast, dem.rast) from forest join dem on 1=1
> > limit 1;
> > ERROR: function st_intersects(raster, raster) is not unique
> > LINE 1: select ST_Intersects(forest.rast, dem.rast) from forest join...
> > HINT: Could not choose a best candidate function. You might need to add
> > explicit type casts.
> > ********** Error **********
> > SQL state: 42725
> > Hint: Could not choose a best candidate function. You might need to add
> > Character: 8
> Strange.  What version of PostgreSQL and PostGIS are you running?  And
> on which OS (Linux, Windows, OSX)?
> Did you load the rtpostgis.sql file into the database after loading
> postgis.sql?  What do you get when you run:
> SELECT postgis_raster_lib_version()
> -bborie
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111013/3d9e8602/attachment.html>
