[postgis-users] ST_Intersect(raster, raster)
Bborie Park
bkpark at ucdavis.edu
Thu Oct 13 07:58:53 PDT 2011
Definitely update. PostGIS Raster should continue developing at a
rapid pace until the end of November when the code freeze happens.
-bborie
On Thu, Oct 13, 2011 at 7:52 AM, Joan <wamaithajoan at gmail.com> wrote:
> Oh really, that would make sense because I have r7693.
> On 13 October 2011 16:44, Bborie Park <bkpark at ucdavis.edu> wrote:
>> On Thu, Oct 13, 2011 at 7:27 AM, Joan <wamaithajoan at gmail.com> wrote:
>> > Hello,
>> > When I run the following query I get the error below. Anyone knows a
>> > solution?
>> > select ST_Intersects(forest.rast, dem.rast) from forest join dem on 1=1
>> > limit 1;
>> > ERROR: function st_intersects(raster, raster) is not unique
>> > LINE 1: select ST_Intersects(forest.rast, dem.rast) from forest join...
>> > HINT: Could not choose a best candidate function. You might need to add
>> > explicit type casts.
>> > ********** Error **********
>> > SQL state: 42725
>> > Hint: Could not choose a best candidate function. You might need to add
>> > Character: 8
>> Strange. What version of PostgreSQL and PostGIS are you running? And
>> on which OS (Linux, Windows, OSX)?
>> Did you load the rtpostgis.sql file into the database after loading
>> postgis.sql? What do you get when you run:
>> SELECT postgis_raster_lib_version()
>> -bborie
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
UC Davis
530-752-8380
