[postgis-users] configure: error: GDAL Python bindings required by raster2pgsql.py loader
William Kyngesburye
woklist at kyngchaos.com
Tue Oct 18 06:28:47 PDT 2011
I don't think GDALFPolygonize is the problem, that's just a test for a new feature in development GDAL and it's OK if it fails. After that should be the "checking for GDAL Python bindings" info.
On Oct 17, 2011, at 10:28 PM, Puneet Kishor wrote:
> On Oct 17, 2011, at 9:22 PM, William Kyngesburye wrote:
>> Try looking in config.log for a more detailed explanation why it couldn't find GDAL python.
> I see stuff like this...
> configure:19000: result: TOPOLOGY: Topology support requested
> configure:19023: result: RASTER: Raster support requested
> configure:19111: checking for GDAL >= 1.6.0
> configure:19145: result: found
> configure:19148: checking for GDALFPolygonize in -lgdal
> configure:19173: gcc -o conftest -g -O2 -I/opt/local/include -I/opt/local/include -I/opt/local/include/libxml2 conftest.c -lgdal -lxml2 -L/opt/local/lib -lxml2 -lz -lpthread -liconv -lm >&5
> Undefined symbols for architecture x86_64:
> "_GDALFPolygonize", referenced from:
> _main in cclcxE0h.o
> ld: symbol(s) not found for architecture x86_64
> and..
> GDALFPOLYGONIZE=''
> GEOSCONFIG='/opt/local/bin/geos-config'
> GEOS_CPPFLAGS='-I/opt/local/include'
> GEOS_LDFLAGS='-L/opt/local/lib'
> and perhaps
> #define HAVE_LIBGEOS_C 1
> #define POSTGIS_GEOS_VERSION 33
> #define HAVE_CFPREFERENCESCOPYAPPVALUE 1
> #define HAVE_CFLOCALECOPYCURRENT 1
> #define POSTGIS_PROJ_VERSION 47
> #define HAVE_LIBPROJ 1
> #define POSTGIS_DEBUG_LEVEL 0
> #define POSTGIS_PROFILE 0
> #define POSTGIS_VERSION "2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> #define POSTGIS_LIB_VERSION "2.0.0SVN"
> #define POSTGIS_BUILD_DATE "2011-10-18 02:30:06"
> #define POSTGIS_SCRIPTS_VERSION "2.0 r7940"
> #define POSTGIS_AUTOCACHE_BBOX 1
> #define POSTGIS_USE_STATS 1
> #define POSTGIS_RASTER_MAJOR_VERSION "0"
> #define POSTGIS_RASTER_MINOR_VERSION "1"
> #define POSTGIS_RASTER_MICRO_VERSION "6d"
> #define POSTGIS_RASTER_VERSION "0.1"
> #define POSTGIS_RASTER_LIB_VERSION "0.1.6d"
> #define POSTGIS_RASTER_BUILD_DATE "2011-10-18 02:30:06"
> #define POSTGIS_RASTER_SCRIPTS_VERSION "0.1.6d"
> #define GDALFPOLYGONIZE 0
> Other than that, I can't really tell.
>> On Oct 17, 2011, at 8:48 PM, Puneet Kishor wrote:
>>> Any suggestions, anyone? As shown below, I believe I have the Python bindings for GDAL installed, yet, I get the following error
>>> checking for GDAL >= 1.6.0... found
>>> checking for GDALFPolygonize in -lgdal... no
>>> checking for GDAL Python bindings... not found
>>> I am not quite sure how to convince the .configure script that I do have gdal w/Python.
>>> On Oct 16, 2011, at 2:31 PM, Mr. Puneet Kishor wrote:
>>>> From: "Mr. Puneet Kishor" <punkish at eidesis.org>
>>>> Subject: configure: error: GDAL Python bindings required by raster2pgsql.py loader
>>>> Date: October 16, 2011 2:29:19 PM CDT
>>>> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>>>> I believe I did install the GDAL Python bindings (via MacPorts), but my PostGIS 2.0 configure script claims I don't have it. Is there are way I can determine whether or not I have the bindings installed? (I am not Python-savvy) But, I do see stuff like so
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
