[postgis-users] st_makeline group by issues
Jeff Adams Jeff.Adams at noaa.gov
Tue Oct 18 10:34:31 PDT 2011
I am having some difficulties getting the st_makeline to work properly when
using a group by clause with multiple items. My query is of the format:
SELECT
b.id,
b.var1,
b.var2,
b.var3,
round(st_length(st_transform(st_makeline(b.the_point), 2163)) *
0.000539956803::double precision) AS length
FROM
  SELECT
  a.id,
  a.var1,
  a.var2,
  a.var3,
  a.time,
  a.the_point
  FROM
  table a
  ORDER BY
  a.time
) b
GROUP BY
b.id,
b.var1,
b.var2,
b.var3
When I execute the above, I get incorrect results. If I combine id, var1,
var2, and var3 into a single variable (e.g. assign unique id's to all unique
combinations of the four variables) and then execute the query below, the
query produces the correct results.
SELECT
b.combined_id,
FROM
  SELECT
  a.combined_id
  FROM
  table a
  ORDER BY
  a.time
) b
GROUP BY
b.combined_id
Any thoughts would e greatly appreciated...
Jeff
