[postgis-users] st_makeline group by issues
Paragon Corporation lr at pcorp.us
Tue Oct 18 19:07:55 PDT 2011
Jeff,
If you are using PostgreSQL 9.0+ you can use the new ORDER BY for aggregates
which is bullet-proof as fara s sorting.
 SELECT
 b.id,
 b.var1,
 b.var2,
 b.var3,
 round(st_length(st_transform(st_makeline(b.the_point ORDER BY b.time),
2163))
 * 0.000539956803::double precision) AS length
FROM a AS b
 GROUP BY
b.id,
 b.var1,
 b.var2,
 b.var3
BTW: The PostgreSQL 9.0 syntax is documented in latest PostGIS manual.
http://www.postgis.org/documentation/manual-svn/ST_MakeLine.html
Hope that helps,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Jeff Adams
> Sent: Tuesday, October 18, 2011 1:35 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] st_makeline group by issues
> I am having some difficulties getting the st_makeline to work
> properly when using a group by clause with multiple items. My
> query is of the format:
> SELECT
> b.id,
> b.var1,
> b.var2,
> b.var3,
> round(st_length(st_transform(st_makeline(b.the_point), 2163))
> * 0.000539956803::double precision) AS length FROM (
>   SELECT
>   a.id,
>   a.var1,
>   a.var2,
>   a.var3,
>   a.time,
>   a.the_point
>   FROM
>   table a
>   ORDER BY
>   a.time
> ) b
> GROUP BY
> b.id,
> b.var1,
> b.var2,
> b.var3
> When I execute the above, I get incorrect results. If I
> combine id, var1, var2, and var3 into a single variable (e.g.
> assign unique id's to all unique combinations of the four
> variables) and then execute the query below, the query
> produces the correct results.
> SELECT
> b.combined_id,
>   SELECT
>   a.combined_id
>   FROM
>   table a
>   ORDER BY
>   a.time
> ) b
> GROUP BY
> b.combined_id
> Any thoughts would e greatly appreciated...
> Jeff
> postgis-users mailing list
