[postgis-users] Postgis 1.5.3 regression test failures
Stephen Davies
sdavies at sdc.com.au
Wed Oct 19 16:57:29 PDT 2011
I totally zapped the postgis source tree and started again from the tarball.
Same result.
However, this time I captured the PostgreSQL log. For the period of the make
check run, the log is 5577 lines long but the first few lines are:
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
LOG: unexpected EOF on client connection
ERROR: parse error - invalid geometry at character 14
HINT: "POINT()" <-- parse error at position 7 within geometry
STATEMENT: select '50', 'POINT()'::GEOMETRY as geom;
HINT: "POINT(1)" <-- parse error at position 8 within geometry
STATEMENT: select '51', 'POINT(1)'::GEOMETRY as geom;
HINT: "POINT(," <-- parse error at position 7 within geometry
STATEMENT: select '52', 'POINT(,)'::GEOMETRY as geom;
Obviously I am missing something crucial but I cannot see what.
Cheers and thanks,
Stephen
On Wednesday 19 October 2011 21:33:34 Sandro Santilli wrote:
> On Wed, Oct 19, 2011 at 01:11:59PM +1030, Stephen Davies wrote:
> > I then proceeded to create a parallel 9.0.4 PostgreSQL environment and to
> > rebuild PostGIS 1.5.3 against that.
> Is just a guess but make sure to do a _full_ rebuild (no object files
> around, no config caches, and rerun ./configure).
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
Stephen Davies Consulting P/L Voice: 08-8177 1595
Adelaide, South Australia. Fax : 08-8177 0133
Records & Collections Management. Mobile:040 304 0583
