[postgis-users] Postgis 1.5.3 regression test failures
Sandro Santilli
strk at keybit.net
Thu Oct 20 01:10:21 PDT 2011
On Thu, Oct 20, 2011 at 10:27:29AM +1030, Stephen Davies wrote:
> I totally zapped the postgis source tree and started again from the tarball.
> Same result.
> However, this time I captured the PostgreSQL log. For the period of the make
> check run, the log is 5577 lines long but the first few lines are:
> LOG: database system is ready to accept connections
> LOG: autovacuum launcher started
> LOG: unexpected EOF on client connection
> ERROR: parse error - invalid geometry at character 14
> HINT: "POINT()" <-- parse error at position 7 within geometry
> STATEMENT: select '50', 'POINT()'::GEOMETRY as geom;
> HINT: "POINT(1)" <-- parse error at position 8 within geometry
> STATEMENT: select '51', 'POINT(1)'::GEOMETRY as geom;
> HINT: "POINT(," <-- parse error at position 7 within geometry
> STATEMENT: select '52', 'POINT(,)'::GEOMETRY as geom;
> Obviously I am missing something crucial but I cannot see what.
A bug in the code producing those strings, obviously.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
