[postgis-users] Tiger Geocoder: SELECT loader_generate_script( -- all states -- , 'sh') ??
Paragon Corporation lr at pcorp.us
Thu Oct 20 17:05:30 PDT 2011
Steve,
As mentioned in other note.  We already do. If René is seeing something
else, then something is wrong with his install.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Thursday, October 20, 2011 7:52 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Tiger Geocoder: SELECT loader_generate_script(
On 10/20/2011 6:22 PM, René Fournier wrote:
> This:
> SELECT loader_generate_script(ARRAY['DC','RI'], 'windows');
returns a shell script that will wget the Tiger data for the states
> of DC and Rhode Island. And, aside from a couple small bugs, works
> very well. I was wondering if there were a shorthand for generating a
> shell script that will fetch ALL STATES?
> On a related note: These scripts appear to consolidate all the states
> into the same tables -- I was wondering if splitting them up into
> separate state-specific tables would improve performance? Anyone try
> it?
It might be interesting to use inherited tables where each state is in it's
own table then use table constraints to select which tables need to be used
or excluded.
-Steve
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
