[postgis-users] Problem installing PostgreSQL 9.0 via Macports on	OS X Server 10.6
    René Fournier
    m5 at renefournier.com
    Sun Oct 23 17:16:54 PDT 2011
	--->  Installing postgresql90-server @9.0.5_0
	To create a database instance, after install do
	 sudo mkdir -p /opt/local/var/db/postgresql90/defaultdb
	 sudo chown postgres:postgres /opt/local/var/db/postgresql90/defaultdb
	 sudo su postgres -c '/opt/local/lib/postgresql90/bin/initdb -D /opt/local/var/db/postgresql90/defaultdb'
	To tweak your DBMS, consider increasing kern.sysv.shmmax by adding an increased kern.sysv.shmmax .. to /etc/sysctl.conf
	--->  Activating postgresql90-server @9.0.5_0
	--->  Cleaning postgresql90-server
	Sun Oct 23 12:45:49 -- server :: sudo mkdir -p /opt/local/var/db/postgresql90/defaultdb
	Sun Oct 23 12:48:41 -- server :: sudo chown postgres:postgres /opt/local/var/db/postgresql90/defaultdb
	chown: postgres: Invalid argument
	Sun Oct 23 12:48:51 -- server ::
So, according to the above instructions (and the tutorials I've read), this should simply work. What am I missing?
On a different note, I have a couple questions concerning PostgreSQL security:
1. My understanding is that making the defaultdb directory owned by the postgres user is for security. Correct?
2. Whenever starting psql, I have on my own machines had to specify "psql -U postgres", because:
	Sun Oct 23 14:27:28 -- Frodo :: psql
	psql: FATAL: role "rene" does not exist
	So, I do I need to add a role/user for my OS X user name?
Coming from MySQL, I find the devil is in the details. Just trying to figure things out… Thanks!
…Rene
