[postgis-users] ST_Value
Mateusz Łoskot
mateusz at loskot.net
Tue Oct 25 12:19:37 PDT 2011
On 25 October 2011 17:39, maduako ikechukwu <iykemadu84 at gmail.com> wrote:
> I tried to extract the elavation value of a particular location on the SRTM
> data i loaded on my database
> using the following command
> SELECT ST_Value(rast,ST_Point(-106.2,38.6)) AS Elevation
> From srtm;
> but it only brought out a long elevation column with no value shown.
> What could be the issue?
There is no issue here. You get integer value as it is expected.
ST_Value(raster, location) => value of pixel at given location of given raster
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
