[postgis-users] Placing a random point within a range of distances from existing point, ST_DWithin and ST_Intersects
Stephen V. Mather
svm at clevelandmetroparks.com
Wed Oct 26 07:27:54 PDT 2011
Hi All,
I'm trying to find the problem with my logic in the
following query. I want to randomize a point, and neither place it too
close or too far from the initial point. I'd like to further constrain the
placement of that point so that it stays within certain bounds. Imagine, if
you will sensitive point data that might need a little fuzzing-1) I don't
want to fuzz it too much (outer circle), 2) I don't want it too close to the
original point (inner circle) 3) but I want it to also stay within certain
boundaries in order to retain some verisimilitude, e.g. must stay within
forest boundaries.
I've tested this in PostGIS 1.3.5 on a Windows Server 2003 machine (postgres
8.3), and in PostGIS 2.0 on Debian (with postgres 8.4).
In general, it works really well. Occasionally, I get a point that seems to
meet my first to criteria but not my third
Here's a few hundred of the same point fuzzed:
Function:
CREATE OR REPLACE FUNCTION ST_Donut
( geom GEOMETRY,
-- GEOMETRY point to be processed
dough DOUBLE PRECISION,
-- Outside ring
nut DOUBLE PRECISION,
-- Inside ring
itermax INTEGER,
-- Maximum number of iterations
bite GEOMETRY)
--POLYGON that randomized point must intersect
RETURNS GEOMETRY
-- Returns the randomized point
AS $$
DECLARE
xmin DOUBLE PRECISION;
-- xmin for envelope of donut
ymin DOUBLE PRECISION;
-- ymin for envelope of donut
delta DOUBLE PRECISION;
-- difference between xmax and xmin
pointx DOUBLE PRECISION;
-- output point x
pointy DOUBLE PRECISION;
-- output point y
returnpoint GEOMETRY;
i INTEGER := 0;
-- index integer for while loop
BEGIN
xmin = ST_X( geom ) - dough; -- find min
x, min y for resulting envelope
ymin = ST_Y( geom ) - dough; -- in which
to place initial points
delta = dough*2;
-- for calculating max extent for envelope
WHILE i < itermax LOOP
i = i + 1;
pointx = xmin + delta * random();
-- generate random point value
pointy = ymin + delta * random();
returnpoint = ST_SetSRID( ST_MakePoint(
pointx, pointy ), ST_SRID( geom ) );
EXIT WHEN
ST_DWithin( returnpoint, geom, dough )
-- test to see if inside outer ring
AND NOT
ST_DWithin( returnpoint, geom, nut )
-- test to see if outside inner ring
AND
ST_Intersects( returnpoint, bite )
--test to see if inside inclusion polygon
END LOOP;
IF i > itermax THEN
RAISE NOTICE 'Reached maximum iterations
without placing point inside donut.';
END IF;
RETURN returnpoint; -- return the GEOMETRY
END;
$$ LANGUAGE plpgsql;
To run:
CREATE TABLE donut_bite_test1 AS
SELECT ST_Donut(ST_MakePoint(0, 0), 40, 60, 1000,
ST_Buffer(ST_MakePoint(-60, -60), 60))
UNION ALL
SELECT ST_Donut(ST_MakePoint(0, 0), 60, 40, 1000,
UNION ALL
Etc. etc.
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
<http://www.clemetparks.com/> clevelandmetroparks.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111026/dcaacaaa/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111026/dcaacaaa/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111026/dcaacaaa/attachment-0001.png>
