[postgis-users] compile on solaris 11 sparc
Doug McComber
doug.mccomber at gmail.com
Thu Sep 1 11:38:14 PDT 2011
Thanks Paul, here's the relevant config.log part:
configure:15850: checking for PQserverVersion in -lpq
configure:15875: gcc -o conftest -g -O2 conftest.c -lpq
-L/usr/postgres/9.0-pgdg/lib/64 -lpq >&5
ld: fatal: file /usr/postgres/9.0-pgdg/lib/64/libpq.so: wrong ELF
class: ELFCLASS64
class: ELFCLASS64
ld: fatal: file processing errors. No output written to conftest
collect2: ld returned 1 exit status
My install of PostgreSQL is empty and I'm just using it for some
development work. Should I remove it and install the 32-bit version
instead? I mean, would that be the easiest solution here?
Thanks,
Doug
On 1 September 2011 15:30, Paul Ramsey <pramsey at opengeo.org> wrote:
> The linking test is failing, but it's finding all the other libpq
> components. Check the config.log and see how/why the test is failing.
> From what I see in your mail this is probably a limitation in our
> configure script, not in your system setup.
> P.
> On Thu, Sep 1, 2011 at 11:19 AM, Doug McComber <doug.mccomber at gmail.com> wrote:
>> Hi,
>> I'm trying to compile PostGIS 1.5.3 in Solaris 11 on sparc hardware.
>> I can't get past configure! :) Here is the tail output of that where
>> it fails:
>> checking for pg_config... /usr/postgres/9.0-pgdg/bin/64/pg_config
>> checking PostgreSQL version... PostgreSQL 9.0.4
>> checking libpq-fe.h usability... yes
>> checking libpq-fe.h presence... yes
>> checking for libpq-fe.h... yes
>> checking for PQserverVersion in -lpq... no
>> configure: error: could not find libpq
>> PostgreSQL 9.0.4 was install by downloading a binary from the
>> PostgreSQL website. A find of 'libpq*' shows:
>> ./usr/postgres/9.0-pgdg/lib/64/libpq.so.5
>> ./usr/postgres/9.0-pgdg/lib/64/libpq.a
>> ./usr/postgres/9.0-pgdg/lib/64/libpqwalreceiver.so
>> ./usr/postgres/9.0-pgdg/lib/64/libpq.so.5.3
>> ./usr/postgres/9.0-pgdg/share/locale/zh_TW/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/fr/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/cs/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/zh_CN/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/es/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/tr/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/it/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/pt_BR/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/ta/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/sv/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/ko/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/ru/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/de/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/share/locale/ja/LC_MESSAGES/libpq5-9.0.mo
>> ./usr/postgres/9.0-pgdg/include/64/libpq-fe.h
>> ./usr/postgres/9.0-pgdg/include/64/libpq/libpq-fs.h
>> ./usr/postgres/9.0-pgdg/include/64/internal/libpq-int.h
>> ./usr/postgres/9.0-pgdg/include/64/libpq-events.h
>> ./usr/postgres/9.0-pgdg/include/64/server/libpq
>> ./usr/postgres/9.0-pgdg/include/64/server/libpq/libpq-be.h
>> ./usr/postgres/9.0-pgdg/include/64/server/libpq/libpq-fs.h
>> ./usr/postgres/9.0-pgdg/include/64/server/libpq/libpq.h
>> What am I missing?
>> Thanks,
>> Doug
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
