[postgis-users] compile on solaris 11 sparc
Doug McComber doug.mccomber at gmail.com
Tue Sep 6 06:47:31 PDT 2011
On 6 September 2011 10:19, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Well just for the record - the issue here was that the person who built your
> PostgreSQL binaries used the native Sun compiler on their system hence
> embedding this as the default CC in the PGXS Makefile used by PostGIS. If
> you still wanted to use Solaris then using GCC to build both PostgreSQL and
> PostGIS on your server should give you something that would work.
> HTH,
> Mark.
Thanks Mark.  I'll keep that in mind as I'm sure Solaris will seduce
me again in the future.  It always does!
