[postgis-users] Problem with convex hulls that cross the dateline
Paragon Corporation
lr at pcorp.us
Tue Sep 6 22:18:51 PDT 2011
Sarah,
> I'm having trouble making convex hulls that cross the international
dateline. Imagine 4 points making a square with the international dateline
running down the middle--I would like the convex hull to be that square, but
instead I get a giant rectangle that goes across the entire planet. I've
done some reading, and it sounds like GEOS generally has a hard time dealing
with the dateline--is that accurate?
Yes GEOS only deals with planar coordinates. Geography is the only
geodetic aware type and there is no ConvexHull function for it.
> Does anyone know of a way to get around this? I was thinking that it
might work if I use an SRID that is just like 4326 but with a central
meridian of 180, does that sound like a good plan?
No. You should use a planar projection of some sort. 4326 squashed on a
map is no good. Paul Ramsey might have some thoughts on the matter.
> I'm pretty new to postGIS and I'm not sure how to either find such an
SRID or how to define it--I've been trying to find an explanation of SRID
syntax and so far coming up empty. If anyone has advice for solving this
problem, or for places where I can learn more about defining custom SRIDs,
I'd be really grateful!
You might want to check out http://spatialreference.org
> Here's an example--if you make this table and then look at it in QGIS
(or whatever) along with a world map, you'll see a big rectangle spanning
the entire map. On a map with
> central meridian of zero, I'd want to see half the polygon on the left
side of the map and the other half on the right side.
> CREATE TABLE example AS
> SELECT ST_ConvexHull(
> ST_Collect(ST_GeomFromText('MULTIPOINT(175 5, 175 30, -175 5, -175
30)') ))::geography(Polygon, 4326) ;
My guess is you'll have to cut your area into pieces. Still then its not
that pretty when you try to rejoin.
Sorry couldn't be more help,
Regina
http://www.postgis.us
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110907/dca69b0a/attachment.html>
