[postgis-users] PostGIS 2.0 (SVN rev7683) from source on Lion using MacPorts for dependencies
JP Glutting
jpglutting at gmail.com
Wed Sep 7 02:09:25 PDT 2011
Hi Bborie,
I did get this to work. All the dependencies needed to be compiled
+universal (geos only compiled properly by configuring the compile for an
older version of gcc). See details here:
http://lists.macosforge.org/pipermail/macports-users/2011-August/025349.html
I like using Macports because I don't have to manage all the dependencies by
hand (generally), I can uninstall cleanly, and it upgrades automatically.
The only time things get a little more complicated is when I want a newer
version of a package (like with PostGIS 2.0), but I can live with that.
Cheers,
JP
On Wed, Aug 31, 2011 at 10:56 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> On 08/27/2011 08:59 AM, JP Glutting wrote:
>> I am bumping this post up. I was never able to compile rev 7683 - I am
>> working with revision 7059, which I was able to compile. I am trying to
>> compile revision 7789 now, and I am having the same problem. This is what
>> I
>> get:
>> "_lwgeom_calculate_gbox_**geodetic", referenced from:
>> _compute_geography_stats in geography_estimate.o
>> _geography_gist_selectivity in geography_estimate.o
>> _geography_area in geography_measurement.o
>> "_gserialized_get_type", referenced from:
>> _geography_bestsrid in geography_measurement.o
>> _geography_covers in geography_measurement.o
>> _geography_perimeter in geography_measurement.o
>> "_lwgeom_calculate_gbox_**cartesian", referenced from:
>> "_lwgeom_covers_lwgeom_sphere"**, referenced from:
>> "_gserialized_get_gbox_p", referenced from:
>> _geography_point_outside in geography_measurement.o
>> "_gbox_pt_outside", referenced from:
>> "_lwgeom_area_sphere", referenced from:
>> "_lwgeom_area_spheroid", referenced from:
>> "_gserialized_datum_get_gbox_**p", referenced from:
>> _compute_geometry_stats in geometry_gist_selectivity.o
>> _geometry_gist_sel_2d in geometry_gist_selectivity.o
>> ld: symbol(s) not found for architecture i386
>> collect2: ld returned 1 exit status
>> lipo: can't open input file:
>> /var/folders/k0/lzz_**jzld03d8yg881mnbh7_h0000gp/T//**ccgj6uq8.out (No
>> such file
>> or directory)
>> make[1]: *** [postgis-2.0.so] Error 1
>> make: *** [all] Error 1
>> Is anyone else using Macports? Are there any tricks I could try to get
>> this
>> to compile? I would like to use ST_SummaryStats for some raster analysis I
>> need to do.
>> Thanks,
>> JP
> Have you tried compiling without using Macports? I'm able to compile with
> the following:
> OSX 10.6.8
> Xcode 3.2.6
> Fink 0.31.0
> PostgreSQL 9.0.4
> GEOS 3.3.0
> PROJ 4.7.1
> GDAL trunk r22922
> PostGIS trunk r7791
> All of it was compiled from source. Fink was for libreadline.
> -bborie
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110907/230b3a88/attachment.html>
