[postgis-users] Problem with convex hulls that cross the dateline
pcreso at pcreso.com
Thu Sep 8 18:07:01 PDT 2011
Welcome to maritime GIS around New Zealand :-)
The standard problem!
Work in a 0-360 space instead of +-180. EPSG4326 supports both extents (according to EPSG anyway). The problem is the lack of a flag to specify which you want.
Improvements in the geography datatype will help in this area.
There are a few workarounds, but the only real solution is a mod 360 approach, as used in GMT & in the geography datatype (sort of)
Brent Wood
--- On Fri, 9/9/11, Sarah Berke <skberke at uchicago.edu> wrote:
Subject: Re: [postgis-users] Problem with convex hulls that cross the dateline
To: postgis-users at postgis.refractions.net
Date: Friday, September 9, 2011, 7:22 AM
Thanks very much, Regina, Paul, and Ben for the responses. I don't think my hacking skills are quite up to following Paul's suggestion, but I can try to find an equal area projection for the Pacific Ocean. It seems like that would work. I also rather like the idea of translating the points--if I did that, would it then be easy to just translate the entire hull back into position?
Thanks,
Sarah
_________________________________
Sarah K Berke
Postdoctoral Scholar
Department of the Geophysical Sciences
University of Chicago
5734 S. Ellis Ave
Chicago, IL 60637
Message: 2
Date: Wed, 7 Sep 2011 01:18:51 -0400
dateline
To: "'PostGIS Users Discussion'"
<postgis-users at postgis.refractions.net>
Message-ID: <F8675FD4BB254CD09D2359CF11685DEA at D>
Content-Type: text/plain; charset="us-ascii"
Sarah,
> I'm having trouble making convex hulls that cross the international
dateline. Imagine 4 points making a square with the international dateline
running down the middle--I would like the convex hull to be that square, but
instead I get a giant rectangle that goes across the entire planet. I've
done some reading, and it sounds like GEOS generally has a hard time dealing
with the dateline--is that accurate?
Yes GEOS only deals with planar coordinates. Geography is the only
geodetic aware type and there is no ConvexHull function for it.
> Does anyone know of a way to get around this? I was thinking that it
might work if I use an SRID that is just like 4326 but with a central
meridian of 180, does that sound like a good plan?
No. You should use a planar projection of some sort. 4326 squashed on a
map is no good. Paul Ramsey might have some thoughts on the matter.
> I'm pretty new to postGIS and I'm not sure how to either find such an
SRID or how to define it--I've been trying to find an explanation of SRID
syntax and so far coming up empty. If anyone has advice for solving this
problem, or for places where I can learn more about defining custom SRIDs,
I'd be really grateful!
You might want to check out http://spatialreference.org
> Here's an example--if you make this table and then look at it in QGIS
(or whatever) along with a world map, you'll see a big rectangle spanning
the entire map. On a map with
> central meridian of zero, I'd want to see half the polygon on the left
side of the map and the other half on the right side.
> CREATE TABLE example AS
> SELECT ST_ConvexHull(
> ST_Collect(ST_GeomFromText('MULTIPOINT(175 5, 175 30, -175 5, -175
30)') ))::geography(Polygon, 4326) ;
My guess is you'll have to cut your area into pieces. Still then its not
that pretty when you try to rejoin.
Sorry couldn't be more help,
Regina
http://www.postgis.us
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20110907/dca69b0a/attachment-0001.html>
Message: 3
Date: Tue, 6 Sep 2011 22:21:48 -0700
dateline
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID:
<CACowWR0YVqT5_wasbLoscmCnqNFAqVT2ioA=yJQ6Uv_yX9Cv0A at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
On Tue, Sep 6, 2011 at 10:18 PM, Paragon Corporation <lr at pcorp.us> wrote:
> ?Sarah,
> ?> ?I'm having trouble making convex hulls that cross the international
> Yes GEOS? only deals with planar coordinates.? Geography is the only
Although you could hack one up easily enough by copying the ideas in
ST_Buffer(geography)
P
Message: 4
Date: Wed, 7 Sep 2011 13:43:52 +0800
From: Ben Madin <lists at remoteinformation.com.au>
dateline
Message-ID:
<6AFE8509-2218-4CB2-956A-1269AB5CDB4B at remoteinformation.com.au>
Content-Type: text/plain; charset=us-ascii
Sarah,
I'm sure that there are good reasons not to do this, but could you translate your points left or right, create your convex hull then translate the polygon back...?
Otherwise you could project it onto a custom projection that covers your area of interest? As an example look for an equal area proj string (I know there is one for Australia GDA94 Albers - http://www.spatialreference.org/ref/epsg/3577) and shift the lat and lon parameters...
cheers
Ben
On 07/09/2011, at 1:13 AM, Sarah Berke wrote:
> Hello,
> I'm having trouble making convex hulls that cross the international dateline. Imagine 4 points making a square with the international dateline running down the middle--I would like the convex hull to be that square, but instead I get a giant rectangle that goes across the entire planet. I've done some reading, and it sounds like GEOS generally has a hard time dealing with the dateline--is that accurate? Does anyone know of a way to get around this? I was thinking that it might work if I use an SRID that is just like 4326 but with a central meridian of 180, does that sound like a good plan? I'm pretty new to postGIS and I'm not sure how to either find such an SRID or how to define it--I've been trying to find an explanation of SRID syntax and so far coming up empty. If anyone has advice for solving this problem, or for places where I can learn more about defining custom SRIDs, I'd be really grateful!
> Here's an example--if you make this table and then look at it in QGIS (or whatever) along with a world map, you'll see a big rectangle spanning the entire map. On a map with central meridian of zero, I'd want to see half the polygon on the left side of the map and the other half on the right side.
> ST_Collect(ST_GeomFromText('MULTIPOINT(175 5, 175 30, -175 5, -175 30)') ))::geography(Polygon, 4326) ;
> Thanks very much,
> Sarah
> Sarah K Berke
> 5734 S. Ellis Ave
> Chicago, IL 60637
> postgis-users mailing list
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110908/3f29fa71/attachment.html>
