[postgis-users] Problem moving database
Sveen Atle Frenvik (Geomatikk IKT) Atle.Frenvik.Sveen at geomatikk.no
Wed Sep 14 05:08:03 PDT 2011
You might want to have a look at this blog post, which explains the
problem, and gives the solution
http://blog.cleverelephant.ca/2010/09/postgis-back-up-restore.html
short version: do not store your data in the public schema, and only
dump and restore your data-schema.
-atle
On 2011-09-09 23:52, Michael A. Peters wrote:
> pcreso at pcreso.com wrote:
>> The issue is that you are trying to install an old version of postgis
>> into the new database.
>> My normal approach (yet to fail - for me at least):
>> create the new database
>> install the appropriate/current version of Postgis in that db (this
>> may require plpgsql as well as running postgis.sql &
>> spatial_ref_sys.sql)
>> dump the old db without the "create new db option" & copy the dump
>> file to the new system
>> run psql -d <newdb> -f <old db dump file>
>> (optionally create any users you want in the new db to be compatible
>> with the old db)
>> you will still get errors as it fails to install the old postgis on
>> top of the one that is already there, but that is fine - you don't
>> want or need the old postgis.
>> That should give you a working new db.
> All my GIS data is from shape files, I wonder if the best approach may
> be to just load them fresh rather than as part of the restore - IE
> dump the database without the GIS data tables and restore that, add
> the tables and load from the shape files.
> postgis-users mailing list
Atle Frenvik Sveen
Utvikler
Geomatikk IKT AS
tlf: 45 27 86 89
atle.frenvik.sveen at geomatikk.no
