[postgis-users] PostGIS table doesn't show up in QGIS
Puneet Kishor
punk.kish at gmail.com
Wed Sep 14 19:07:54 PDT 2011
This happens from time to time... I have a table like so
CREATE TABLE foo
gid serial NOT NULL,
the_geom geometry,
CONSTRAINT foo_pk PRIMARY KEY (gid ),
CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 4326)
WITH (
OIDS=FALSE
ALTER TABLE foo
OWNER TO postgres;
CREATE INDEX foo_geom_idx
ON states
USING gist
(the_geom );
Yet, the above table doesn't show up in QGIS open dialog. If I check the box to show tables with no geometry, then the above table shows up as not having any geometry. The table has 20K+ rows, and while a few rows have invalid geometry, for the most part, the table has good data in it.
What is the reason for the above?
Puneet.
