[postgis-users] Populate_geometry_columns() problems
Sandro Santilli strk at keybit.net
Fri Sep 16 03:22:20 PDT 2011
On Thu, Sep 15, 2011 at 11:25:52PM +0200, Andreas Forø Tollefsen wrote:
> Hi all,
> Trying to do a populate_geometry_columns(); but it does not work.
> This is PostGis 2.0 with Gdal 1.8, Geos 3.4
Revision number ?
> Command: SELECT Populate_Geometry_Columns();
> ERROR:  query string argument of EXECUTE is null
> CONTEXT:  PL/pgSQL function "populate_geometry_columns" line 53 at
> EXECUTE statement
> PL/pgSQL function "populate_geometry_columns" line 50 at assignment
> Any ideas?
Update to latest trunk revision, make sure to re-source postgis.sql,
try again. If the problem persists please file ticket.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
