[postgis-users] Trouble adding Postgis 1.5.3 layer to QGis
technique at siig.fr
Fri Sep 23 00:34:01 PDT 2011
Hi every one
I'm using PostGis 1.5.3 and QGis 1.7 and I've troubles adding postgis layers
to QGis.
In the error message given by QGis when I try to add postgis layers, there's
this query which doesn't work any longer although it used to work with
PostGis 1.5.2:
select "oid",asbinary("geom",'NDR') from "cadastre"."commune" where "geom"
&& setsrid('BOX3D(794270.8532559783197939 6312919.8975825672969222,
860762.6940280217677355 6362904.3300199424847960)'::box3d,2154);
After different tests I've found that I must use the geometry() function to
force the first parameter of the setsrid() function to convert into
"geometry" type.
&& setsrid(geometry('BOX3D(794270.8532559783197939 6312919.8975825672969222,
860762.6940280217677355 6362904.3300199424847960)'::box3d),2154);
Is it a Postgis or a Qgis problem? How can I fix that? Since I've upgraded
to Postgis 1.5.3, all my QGis projects are not working any more and the QGis
1.7 doesn't work either (I was using Qgis 1.6 version when it first
occurred, then I've installed the greater version but it didn't change a
thing).
Thanks in advance
Dominique Le Cocq
SiiG (Syndicat Intercommunal dInformation Géographique)
115 Avenue de la Roquette ZA de Berret 30 200 Bagnols-sur-Cèze
Tél: 04.66.90.58.00 Fax: 04.66.82.98.35 Mail: <mailto:dlecocq at siig.fr>
dlecocq at siig.fr Web: <http://www.siig.fr> http://www.siig.fr
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110923/42cbb834/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110923/42cbb834/attachment.gif>
