[postgis-users] Optimizing ST_Intersection
Paul Ramsey
pramsey at opengeo.org
Tue Sep 27 14:11:29 PDT 2011
http://www.sql-tutorial.net/SQL-JOIN.asp
SELECT ST_AsText(ST_Intersection(r.the_geom, p.the_geom)
FROM roads r JOIN pipes p ON ST_Intersects(r.the_geom, p.the_geom)
WHERE p.pipeid = 1;
On Tue, Sep 27, 2011 at 1:56 PM, vinod.khare at gmail.com
<vinod.khare at gmail.com> wrote:
> I have a table containing all roads in the US. Naturally, this table is very
> large with more that 20 million rows. I want to find the intersection of
> these roads with a single linestring (representing a pipeline).
> (SELECT the_geom FROM roads)
> (SELECT the_geom FROM pipes WHERE pipeid = 1)));
> I have created a gist index on roads but the query planner does not use it.
> The query takes a really long time. Is there some way to optimize this?
> thanks,
> Vinod.
> postgis-users mailing list
