[postgis-users] shp2pgsql nulls
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Sep 29 08:05:04 PDT 2011
On 29/09/11 15:01, Andy Colson wrote:
> Hey Mark, I may have guessed wrong. I got a response from the gdal folk,
> who said "the null values for Date in this dbf file were indicated by a
> string filled with spaces".
> Would still be neet if something could be done so shp2pgsql could import
> this. The shapefile is 16 Meg, and uncompresses to 157 Meg, you can get
> it here:
> http://squeakycode.net/parcelAnnoV2.zip
> Version: is this what you are looking for?
> RCSID: $Id: shp2pgsql-core.h 5983 2010-09-19 11:27:05Z mcayland $
> RELEASE: 1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> -Andy
Hi Andy,
Thanks for the example, but I don't appear to be able to recreate this here:
pg90 at zeno:~/datasets$ shp2pgsql ParcelAnnoV2 > test.sql
pg90 at zeno:~/datasets$ psql -d postgis15 -f test.sql
postgis15=# \d parcelannov2
                                    Table "public.parcelannov2"
    Column   |          Type          |
Modifiers
  gid        | integer                | not null default
nextval('parcelannov2_gid_seq'::regclass)
  textstring | character varying(254) |
  fontname   | character varying(254) |
  fontsize   | numeric                |
  bold       | smallint               |
  italic     | smallint               |
  underline  | smallint               |
  verticalal | smallint               |
  horizontal | smallint               |
  xoffset    | numeric                |
  yoffset    | numeric                |
  angle      | numeric                |
  fontleadin | numeric                |
  wordspacin | numeric                |
  characterw | numeric                |
  characters | numeric                |
  flipangle  | numeric                |
  override   | integer                |
  featype    | smallint               |
  bptype     | smallint               |
  book       | integer                |
  page       | integer                |
  recorded   | date                   |
  taskid     | integer                |
  the_geom   | geometry               |
Indexes:
     "parcelannov2_pkey" PRIMARY KEY, btree (gid)
Check constraints:
     "enforce_dims_the_geom" CHECK (st_ndims(the_geom) = 2)
     "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL)
     "enforce_srid_the_geom" CHECK (st_srid(the_geom) = (-1))
postgis15=# select * from parcelannov2 where gid = 1;
  gid | textstring | fontname |   fontsize    | bold | italic |
underline | verticalal | horizontal |    xoffset    |    yoffset    |
   angle     |  fontleadin   |  wordspacin   |  characterw   |
   characters   |   flipangle   | override | featype | bptype | book |
page | recorded | taskid | the_geom
    1 |            |          | 0.00000000000 |    0 |      0 |
0 |          0 |          0 | 0.00000000000 | 0.00000000000 |
0.00000000000 | 0.00000000000 | 0.00000000000 | 0.00000000000 |
  0.00000000000 | 0.00000000000 |        0 |      20 |     20 |    0 |
   0 |          |      0 |
(1 row)
postgis15=# select * from parcelannov2 where gid = 1 and recorded is null;
   0 |          |      0 |
(1 row)
That seems to indicate that the recorded date field is set to NULL as
intended? This is using the current 1.5 branch HEAD.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
