[postgis-users] shp2pgsql nulls
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Sep 29 08:46:22 PDT 2011
On 29/09/11 16:38, Andy Colson wrote:
> Oh, buggers. I had problems with this shapefile and tried several
> different things, and I forgot to mention an important step. Which
> probably takes the error out of postgis territory.
> See, I want to change the projection. So I ran ogr2ogr from ParcelAnnoV2
> to temp_shapefile first, then shp2pgsql on temp_shapefile would give me
> invalid date errors. Sorry. I've got too many things going on and
> messing things up.
> The gdal people said the patch was applied to the shapefile driver:
> http://lists.osgeo.org/pipermail/gdal-dev/2011-September/030276.html
> So I'm wondering if with that fix, the shape->shape would produce a new
> shapefile that shp2pgsql would import just fine.
> I still have not had a chance to try out their fix, but at this point I
> think all is well, and I've wasted enough of your time, we can call this
> resolved.
Ah yes - that looks like an ogr2ogr bug. Never mind.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
