[postgis-users] Convert from character to timestamptz
Mathieu Basille
basille at ase-research.org
Fri Sep 30 18:10:27 PDT 2011
Le 30/09/2011 17:49, Sandro Santilli a écrit :
>> You're right, I'm being too vague (in my defence, error messages are
>> in French for me!).
> See if exporting LANG=C helps there.
Did you mean at the command line or in the SQL query window? I tried
both with no success.
I also tried to launch pgAdmin with 'LC_ALL=C pgadmin3', but error
messages were still in French. What's weird is that the whole software
runs in English!
> I was wrong about the syntax, but the idea is that you tell it
> how to do the conversion. Maybe it was USING instead of WITH.
> The definitive answer is in the PostgreSQL reference manual, under
> the SQL section, in the ALTER TABLE syntax.
That's beautiful! I've seen this page previously, but couldn't figure
out what was the correct command for my case. Now, with:
ALTER TABLE test
ALTER COLUMN date TYPE timestamptz
USING date::timestamptz;
I have now date as a 'timestamptz'! I checked, and the timezone is taken
into account (winter times are GMT-5, summer times are GMT-4). I think
I'm starting to understand the mistakes I made and the rationale behind
this command.
Sandro, thanks a lot!
Mathieu.
~$ whoami
Mathieu Basille, Post-Doc
~$ locate
Laboratoire d'Écologie Comportementale et de Conservation de la Faune
+ Centre d'Étude de la Forêt
Département de Biologie
Université Laval, Québec
~$ info
http://ase-research.org/basille
~$ fortune
``If you can't win by reason, go for volume.''
Calvin, by Bill Watterson.
