[postgis-users] Easiest web-gis for choropleth map or should I use QGIS plugin?
John Abraham
jea at hbaspecto.com
Mon Apr 2 09:48:53 PDT 2012
I've been looking for an open-source and easily deployable solution to allow users to view choropleth maps of PostGIS layers. The layers are straightforward enough, just a geometry column, a GID, and then a bunch of value columns. I simply want the user to be able to use his own computer resources to select the value columns, select the ranges of the classes for the colors, and perhaps select the color ramp. I already have a Django project which allows the user to generate the layers (select the appropriate geometry and value columns and crosstab them into a single PostGIS view.)
We have a partially implemented system using Mapserver and Openlayers, but the maps are delivered as bitmaps by the server, which means sending full bitmaps every time the user changes the ranges or selects a different value column. Here are the technologies I think I can use to do it in the browser alongside my existing Django code:
1) Javascript, probably GeoEXT http://geoext.org/ using open layers, so the browser draws the map, it seems this should be dead-easy and there should be a cut-n-paste example out there but I've been struggling a bit trying to find one,
2) Java applet, there must be one out there I can customize but I haven't found one yet (admittedly haven't looked too hard yet for a Java applet, because I've been preferring the idea of Javascript)
3) Adobe flash/flex, I have no experience with this and the development environment is not open-source, but it looks pretty flexible. I can probably grab code from a colleague of mine who does have something similar already working, but when I looked his code it looked pretty complex internally and it used a few non-open-source libraries.
Any suggestions or thoughts? I have a feeling that there is A Very Easy Solution out there that I'm not finding.
Alternatively, I could use
4) a QGIS plugin, abandoning the web interface all together, moving my existing python code for generating the layer out of Django and into QGIS, then using QGIs to view the layer. This would require me to deliver and support QGIS.
John Abraham
