[postgis-users] raster2pgsql
JamesH
james.holmes at newcastle.ac.uk
Tue Apr 3 05:46:53 PDT 2012
Removed the -M and seems to have run however unlike the usual 1 row in the
table, it has generated 64 rows each with different rast values. This seems
to me to be wrong but at present I'm having difficulty viewing through QGIS
or OpenJump so can't visually examine.
It did return a new output message (below) which seems to be alright minus a
few constraints missing:
NOTICE: CREATE TABLE will create implicit sequence
"height_newcastle_rid_seq" for serial column "height_newcastle.rid"
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"height_newcastle_pkey" for table "height_newcastle"
NOTICE: Adding SRID constraint
CONTEXT: PL/pgSQL function "addrasterconstraints" line 53 at RETURN
NOTICE: Adding scale-X constraint
NOTICE: Adding scale-Y constraint
NOTICE: Adding blocksize-X constraint
NOTICE: Adding blocksize-Y constraint
NOTICE: Adding alignment constraint
NOTICE: Adding number of bands constraint
NOTICE: Adding pixel type constraint
NOTICE: Unable to get the pixel types of a sample raster
CONTEXT: PL/pgSQL function "addrasterconstraints" line 91 at assignment
WARNING: Unable to add constraint: 'pixel_types'. Skipping
NOTICE: Adding nodata value constraint
NOTICE: Unable to get the nodata values of a sample raster
CONTEXT: PL/pgSQL function "addrasterconstraints" line 94 at assignment
WARNING: Unable to add constraint: 'nodata_values'. Skipping
NOTICE: Adding out-of-database constraint
NOTICE: Unable to get the out-of-database bands of a sample raster
CONTEXT: PL/pgSQL function "addrasterconstraints" line 97 at assignment
WARNING: Unable to add constraint: 'out_db'. Skipping
NOTICE: Adding maximum extent constraint
Query result with 1 row discarded.
Query returned successfully with no result in 375 ms.
"By chance, are you making changes to the sql file outputted by the loader?"
No Bborie, not from running raster2pgsql through to opening the sql file and
running it in PostgreSQL.
"paste here the output of: SELECT postgis_full_version()"
POSTGIS="2.0.0beta4" GEOS="3.3.3dev-CAPI-1.7.3" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8" USE_STATS (procs
from 2.0 r8238 need upgrade)
I believe beta4 was installed ok?
Regards,
James
View this message in context: http://postgis.17.n6.nabble.com/raster2pgsql-tp4679577p4681883.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
