[postgis-users] raster2pgsql
Salvatore Larosa
lrssvtml at gmail.com
Tue Apr 3 06:16:19 PDT 2012
Hi
Il giorno mar, 03/04/2012 alle 05.46 -0700, JamesH ha scritto:
> Removed the -M and seems to have run however unlike the usual 1 row in the
> table, it has generated 64 rows each with different rast values. This seems
> to me to be wrong but at present I'm having difficulty viewing through QGIS
> or OpenJump so can't visually examine.
the -M parameter should not be a problem! For me it works fine!
> It did return a new output message (below) which seems to be alright minus a
> few constraints missing:
> NOTICE: CREATE TABLE will create implicit sequence
> "height_newcastle_rid_seq" for serial column "height_newcastle.rid"
> NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
> "height_newcastle_pkey" for table "height_newcastle"
> NOTICE: Adding SRID constraint
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 53 at RETURN
> NOTICE: Adding scale-X constraint
> NOTICE: Adding scale-Y constraint
> NOTICE: Adding blocksize-X constraint
> NOTICE: Adding blocksize-Y constraint
> NOTICE: Adding alignment constraint
> NOTICE: Adding number of bands constraint
> NOTICE: Adding pixel type constraint
> NOTICE: Unable to get the pixel types of a sample raster
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 91 at assignment
> WARNING: Unable to add constraint: 'pixel_types'. Skipping
> NOTICE: Adding nodata value constraint
> NOTICE: Unable to get the nodata values of a sample raster
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 94 at assignment
> WARNING: Unable to add constraint: 'nodata_values'. Skipping
> NOTICE: Adding out-of-database constraint
> NOTICE: Unable to get the out-of-database bands of a sample raster
> CONTEXT: PL/pgSQL function "addrasterconstraints" line 97 at assignment
> WARNING: Unable to add constraint: 'out_db'. Skipping
> NOTICE: Adding maximum extent constraint
> Query result with 1 row discarded.
> Query returned successfully with no result in 375 ms.
> "By chance, are you making changes to the sql file outputted by the loader?"
> No Bborie, not from running raster2pgsql through to opening the sql file and
> running it in PostgreSQL.
> "paste here the output of: SELECT postgis_full_version()"
> POSTGIS="2.0.0beta4" GEOS="3.3.3dev-CAPI-1.7.3" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8" USE_STATS (procs
> from 2.0 r8238 need upgrade)
> I believe beta4 was installed ok?
Postgis has not been upgraded correctly! You have to run
postgis_upgrade_20_minor.sql, found in postgis folder, to upgrade
"procs" postgis!
Not sure if this helps you solve the problem!
> Regards,
> James
Regards,
-SL
