[postgis-users] Severe shapefile upload issues
Paragon Corporation lr at pcorp.us
Thu Apr 5 15:54:48 PDT 2012
It sounds like you might have a mix of postgis installs.  Did you upgrade
from a prior version and how did you do it?
What does
SELECT postgis_full_verion();
return.
I just moved my postgis extension from public to postgis schema.  Added
postgis to my search path and then imported a shape file with the gui loader
and had no issues.
Thanks,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of THX1138
> Sent: Thursday, April 05, 2012 6:06 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Severe shapefile upload issues
> I am working with postgis 2.0.0 and have found several issues
> when trying to upload shapefiles into a postgis database.
> The most pressing issue I have found is that when setting up
> the postgis extension in a schema other than public,
> AddGeometryColumn() completely fails to do anything.
> For example I used shp2pgsql to try to test upload a
> shapefile using the following command:
> shp2pgsql -c -s 2277:4326  -i -I "C:\tcad2\20120301_TCAD
> SHAPEFILES\MUD.shp"
> postgis.mudtest | psql ...options
> which creates the following sql:
> SET CLIENT_ENCODING TO UTF8;
> SET STANDARD_CONFORMING_STRINGS TO ON;
> BEGIN;
> CREATE TABLE "postgis"."mudtest" (gid serial, "objectid"
> int4, "tcmud_name" varchar(50), "shape_area" numeric,
> "shape_len" numeric); ALTER TABLE "postgis"."mudtest" ADD
> PRIMARY KEY (gid); SELECT
> AddGeometryColumn('postgis','mudtest','geom','4326','MULTIPOLYGON',2);
> INSERT INTO "postgis"."mudtest"
> ("objectid","tcmud_name","shape_area","shape_len",geom)
> VALUES ('14','LAKEWAY
> MUD','9.60083055833e+004','1.24005179036e+003',ST_Transform('0
106000020E50800000100000001030000000100000005000000E03113F38C20474188DA1ADB9
142634140726A6B94204741B07B4EE669426341007FCF91FE1F4741D0BE4D2668426341A03E>
7819F71F474190631C1B90426341E03113F38C20474188DA1ADB91426341',
> 4326));
> CREATE INDEX "mudtest_geom_gist" ON "postgis"."mudtest" USING
> GIST ("geom"); COMMIT;
> When AddGeometryColumn is run, I receive the following error:
> ERROR:  function addgeometrycolumn(unknown, character
> varying, character varying, character varying, integer,
> character varying, integer, boolean) does not exist LINE 1:
> SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7)
> HINT:  No function matches the given name and argument types.
> You might need to add explicit type casts.
> QUERY:  SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7)
> CONTEXT:  PL/pgSQL function "addgeometrycolumn" line 5 at SQL
> statement
> ********** Error **********
> ERROR: function addgeometrycolumn(unknown, character varying,
> character varying, character varying, integer, character
> varying, integer, boolean) does not exist SQL state: 42883
> Hint: No function matches the given name and argument types.
> Context: PL/pgSQL function "addgeometrycolumn" line 5 at SQL statement
> I verified that the function does in fact exist within the
> postgis schema and then even tried explicitly casting the
> arguments in the following way so that they would match exactly:
> SELECT
> postgis.AddGeometryColumn('postgis'::varchar,'mudtest'::varcha
> r,'geom'::varchar,4326,'MULTIPOLYGON'::varchar,2
> true);
> but I had no luck, and when I tested in another database
> where the postgis extension is installed in public it worked
> without complaint.
> I created the postgis extensions in my first database as follows:
> create schema postgis;
> create extension postgis with schema postgis; GRANT ALL ON
> SCHEMA postgis TO postgres; GRANT ALL ON SCHEMA postgis TO
> public; set search_path to postgis, "$user",public
> I figured this would pretty much take care of everything that
> could possibly cause any problemes, but I horribly mistaken
> in that regard.
> The second issue comes with the srid conversion itself --even
> in cases when I import to a database where the postgis
> extension is in the public schema.
> ERROR:  function st_transform(unknown, integer) is not unique
> LINE 11: ...AY
> MUD','9.60083055833e+004','1.24005179036e+003',ST_Transfo...
> HINT:  Could not choose a best candidate function. You might
> SQL state: 42725
> Hint: Could not choose a best candidate function. You might
> Character: 495
> In this case it appears that the geometry field is simply not
> being recognized as such and thus confusing the function.
> Does anyone know why these issues are occurring and how I
> might fix them?
>  I realize I could just programatically edit the sql to
> bypass using AddGeometryColumn and then add  in
> ::geometry(MULTIPOLYGON,srid) after the geometry string and
> then upload the edited sql into the database but I am hoping
> there is a better .
> If anyone has a script that does this already (in a fast
> efficient manner)please let me know! Otherwise, I will just
> write one in python.
> As a side note, I noticed that the gui shapefile uploader no
> longer has the srid convert option, so I am wondering if this
> feature has been deprecated since it does not work and the
> documentation has just not been updated to reflect this change.
> I will also note that if I upload a shapefile into a database
> with the postgis extension set to public and then alter the
> extenion to postgis, most of the postgis functions seem to work fine.
> Thanks!
> THX1138
> http://postgis.17.n6.nabble.com/Severe-shapefile-upload-issues
> -tp4690980p4690980.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
