[postgis-users] Help please with PL/R
Gery .
gamejihou at hotmail.com
Mon Apr 9 10:31:35 PDT 2012
Hello,
Since a while I've been searching a way of smoothing long/lat data coming from ship tracks using Loess from PL/R. I found David Bitner's method (link below), here the links:
post: http://postgis.refractions.net/pipermail/postgis-users/2010-October/030264.html
image output: http://postgis.refractions.net/pipermail/postgis-users/attachments/20101015/b8efb3e7/attachment.png
I've been trying to reproduce what he did but had have no success in getting work with my data. My table of points looks like:
id | fldr | sx | sy | profile
1 | 1 | -70.7033 | -26.5362 | LF
2 | 2 | -70.7033 | -26.5362 | LF
3 | 3 | -70.7033 | -26.5362 | LF
4 | 4 | -70.7033 | -26.5362 | LF
5 | 5 | -70.7033 | -26.5362 | LF
6 | 6 | -70.7033 | -26.5362 | LF
7 | 7 | -70.7033 | -26.5362 | LF
8 | 8 | -70.7033 | -26.5362 | LF
9 | 9 | -70.7033 | -26.5362 | LF
10 | 10 | -70.7033 | -26.5362 | LF
11 | 11 | -70.7033 | -26.5362 | LF
12 | 12 | -70.7033 | -26.5362 | LF
13 | 13 | -70.7033 | -26.5362 | LF
14 | 14 | -70.7033 | -26.5362 | LF
15 | 15 | -70.7033 | -26.5362 | LF
16 | 16 | -70.7033 | -26.5362 | LF
17 | 17 | -70.7033 | -26.5362 | LF
18 | 18 | -70.7033 | -26.5362 | LF
19 | 19 | -70.7033 | -26.5362 | LF
20 | 20 | -70.7033 | -26.5362 | LF
21 | 21 | -70.7033 | -26.5362 | LF
22 | 22 | -70.7033 | -26.5362 | LF
23 | 23 | -70.7033 | -26.5361 | LF
24 | 24 | -70.7033 | -26.5361 | LF
25 | 25 | -70.7033 | -26.5361 | LF
26 | 26 | -70.7033 | -26.5361 | LF
27 | 27 | -70.7032 | -26.5361 | LF
28 | 28 | -70.7032 | -26.5361 | LF
29 | 29 | -70.7032 | -26.5361 | LF
30 | 30 | -70.7032 | -26.5361 | LF
31 | 31 | -70.7032 | -26.5361 | LF
32 | 32 | -70.7032 | -26.5361 | LF
33 | 33 | -70.7032 | -26.5361 | LF
34 | 34 | -70.7032 | -26.5361 | LF
35 | 35 | -70.7032 | -26.5361 | LF
36 | 36 | -70.7032 | -26.5361 | LF
37 | 37 | -70.7032 | -26.5361 | LF
38 | 38 | -70.7032 | -26.5361 | LF
39 | 39 | -70.7032 | -26.5361 | LF
40 | 40 | -70.7032 | -26.5361 | LF
...(continue up to 245 rows)
as you can see, the first 22 rows in sx/sy (ie. long/lat) are the same, something similar happens up to the end of the table (245 records), I attached an image of this track (yellow) with the smoothed version (red) using Bezier interpolation from here (http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=smooth_line_%28data_management%29).
I've been trying the code below with the following command, using my table of points:
mydb=# select astext(loess(geom)) from rawnav_point_wgs84;
however, it gives this error message:
CREATE FUNCTION
CREATE FUNCTION
psql:smoothingtest.sql:51: ERROR: function loess(double precision[]) does not exist
LINE 8: SELECT loess(array_agg(st_x(point))) AS x, loess(array_ag...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
psql:smoothingtest.sql:53: ERROR: function loess(geometry) does not exist
LINE 1: select astext(loess(geom)) from chanaral_rawnav_point_wgs84;
I think the code below works with a table of points as input, however I tried the table of lines made from these points but didn't work either.
I'd appreciate any support, thanks.
Please find the 'smoothingtest.sql' (modified version of David Bitner's method) here below:
CREATE OR REPLACE FUNCTION loess(double precision [], double precision[])
RETURNS double precision[] AS
$BODY$
x <- arg1
y <- arg2
x.loess <- loess(x ~ y, span=0.75 data.frame(x=x, y=y))
x.predict <- predict(x.loess, data.frame(y=y))
$BODY$
LANGUAGE plr VOLATILE STRICT
COST 100;
CREATE OR REPLACE FUNCTION dump_linestring_points(geometry)
RETURNS SETOF geometry AS
$BODY$
SELECT (
'SRID=' ||
bar ||
';POINT(' ||
foo ||
)::geometry
FROM
regexp_split_to_table(
rtrim(
substring(asewkt($1) from 23)
) as foo , srid($1) as bar
WHERE st_geometrytype($1)='ST_LineString';
$BODY$
LANGUAGE sql IMMUTABLE STRICT
COST 1
ROWS 100;
CREATE OR REPLACE FUNCTION loess(geometry, double precision)
RETURNS geometry AS
$BODY$
SELECT makeline(setsrid(makepoint(x,y),srid($1)))
FROM (
SELECT unnest(x) AS x, unnest(y) AS y
FROM (
SELECT loess(array_agg(st_x(point))) AS x, loess(array_agg(st_y(point))) AS y
FROM (
SELECT dump_linestring_points($1) AS point
) AS foo
) AS bar
) AS baz
$BODY$
LANGUAGE sql VOLATILE
COST 100;
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120409/0f46a29d/attachment.png>
