[postgis-users] 2.0 Install on Windows
Paragon Corporation lr at pcorp.us
Mon Apr 9 16:50:46 PDT 2012
It should be all in share folder.  Note extensions is not in contrib its in
root of share so in the zip you should see a share that has
share/
  contrib
  extension
I think the older zip may have had it not in share, which was incorrect.
The batch script provided should copy the relevant files.  are you using the
batch script?
There is one issue with the batch script which we will fix in the next
rerelease.
It's not copying over the proj folder in contrib/postgis-2.0
aside from that should copy over everything you need.
Hope that helps,
Regina and Leo
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of JamesH
> Sent: Monday, April 09, 2012 10:36 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] 2.0 Install on Windows
> Hi all,
> I'm trying to install the 2.0.0 on Windows, Normally I copy
> the binary structures into the PostgreSQL\9.1 files (i.e.
> contrib --> contrib), and run CREATE EXTENSION postgis; but
> with these new binaries, there are almost no similar files to
> copy from to.
> Can anyone advise on how to copy these binaries in and run
> the installation?
> Much appreciated,
> James
> GIS Undergraduate
> http://postgis.17.n6.nabble.com/2-0-Install-on-Windows-tp47160
85p4716085.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
