[postgis-users] 2.0 Install on Windows
Paragon Corporation
lr at pcorp.us
Tue Apr 10 06:38:26 PDT 2012
If your postgis is in use, you might need to restart your postgresql server
before you can install, since if the postgis-2.0.dll is in use, you won't be
able to overwrite it.
Haven't had issues testing botht he pg91x32 and pg91x64.
Note you still need to run the alter extension on your db to upgarde to
2.0.0 or use pgadmin extension system.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of JamesH
Sent: Tuesday, April 10, 2012 9:26 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] 2.0 Install on Windows
"are you using the batch script?"
I haven't with previous PostGIS versions no, I've preferred copying the file
structures manually to make sure.
Tried it this time however, edited the batchfile variables with my password
and port number etc. and then ran as Administrator.
Returned that some files hadn't copied (included in image). Did I need to
alter the variables marked in the batch file as 'xcopy'?
http://postgis.17.n6.nabble.com/file/n4751762/cmderror2.jpg
Queried the created example_postgis20 database.
SELECT postgis_full_version returned:
"POSTGIS="2.0.0rc2 r9589" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
LIBJSON="UNKNOWN" TOPOLOGY RASTER"
This seems to me that my postgis version is wrong? That I still have Beta4
installed?
Looked to copy the binary structures manually as have done before but I keep
finding that the files in the 2.0.0 binaries are older than the ones in the
PostgreSQL folders from previous installations.
e.g. postgis-2.0.dll in 2.0.0 binaries: Created 27th Jan 2012, Modified 04th
April 2012.
postgis-2.0.dll already in PostgreSQL\9.1\lib: Created 3rd April 2012,
Modified 3rd April 2012.
Is this an issue, should I copy the older ones from the downloaded binaries
or leave the existing ones?
Much appreciated,
James
GIS Undergraduate
View this message in context:
http://postgis.17.n6.nabble.com/2-0-Install-on-Windows-tp4716085p4751762.htm
l
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
