[postgis-users] PostGIS let me remove an edge shared by a topogeometry
Jose Carlos Martinez Llario
jomarlla at cgf.upv.es
Tue Apr 10 12:50:05 PDT 2012
Dear List,
Dont know why PostGIS let me remove an edge which is needed by a
topogeometry (see point c) )
This is a bug or it is the expected behavior?
Thanks in advance,
Jose
a) Layer t3.parcelas with 3 polygons:
SELECT CreateTopology('t3', 0, 0.1);
create table t3.parcelas (gid serial primary key, codigo varchar);
select addtopogeometrycolumn ('t3','t3','parcelas','topogeom','POLYGON');
INSERT INTO t3.parcelas (codigo, topogeom) VALUES ('A', totopogeom
('MULTIPOLYGON(((0 0, 100 0, 100 100, 0 100, 0 0)))'::geometry, 't3', 1,
0.1));
INSERT INTO t3.parcelas (codigo, topogeom) VALUES ('B', totopogeom
('MULTIPOLYGON(((100 0, 200 0, 200 100, 100 100, 100 0)))'::geometry,
't3', 1, 0.1));
INSERT INTO t3.parcelas (codigo, topogeom) VALUES ('C', totopogeom
('MULTIPOLYGON(((200 0, 300 0, 300 100, 200 100, 200 0)))'::geometry,
't3', 1, 0.1));
b) when I try to remove an edge which is needed by a topogeometry
PostGIS throws an error which is ok.
s6=# select ST_RemEdgeModFace ('t3', 2);
NOTICE: Updating next_{right,left}_face of ring edges...
NOTICE: Deletion of edge 2 joins faces 1 and 2
ERROR: TopoGeom 1 in layer 1 (t3.parcelas.topogeom) cannot be
represented healing faces 2 and 1
b) when I try to remove an edge which is needed by a topogeometry but
one of the side is the universal polygon (id 0) PostGIS does not throw
an error:
s6=# select ST_RemEdgeModFace ('t3', 6);
NOTICE: Deletion of edge 6 joins faces 2 and 0
st_remedgemodface
0
c) The topogeometry is an multiopolygon empty
s6=# select st_astext(topogeom::geometry) from t3.parcelas where gid = 2;
st_astext
MULTIPOLYGON EMPTY
