[postgis-users] PostGIS let me remove an edge shared by a topogeometry
Andrea Peri aperi2007 at gmail.com
Tue Apr 10 13:13:07 PDT 2012
I guess you should not write directly on topology schema using create
table, and insert directly.
You should create a second schema where you could create the tables and
insert into.
Please I don't say that this is the reason of your bug, I don't test it,
because I guess this is a bad practice.
I guess the topology schema should be writeable only with the ST functions.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120410/39c8d861/attachment.html>
