[postgis-users] PostGIS let me remove an edge shared by a topogeometry
Sandro Santilli
strk at keybit.net
Wed Apr 11 02:07:53 PDT 2012
On Wed, Apr 11, 2012 at 10:57:57AM +0200, Jose Carlos Martinez wrote:
> Hi Sandro, thanx for the detailed answer.
> The query returns 0 rows:
> s6=# SELECT r.* FROM t3.relation r, t3.parcelas p
> WHERE r.topogeo_id = id(p.topogeom)
> AND r.layer_id = layer_id(p.topogeom)
> AND p.gid = 2;
> topogeo_id | layer_id | element_id | element_type
> (0 rows)
> s6=# select * from t3.relation ;
> 1 | 1 | 1 | 3
> 3 | 1 | 3 | 3
> Even though the topogeometry exists:
> s6=# select gid,(topogeom).* from t3.parcelas;
> gid | topology_id | layer_id | id | type
> 1 | 30 | 1 | 1 | 3
> 2 | 30 | 1 | 2 | 3
> 3 | 30 | 1 | 3 | 3
Bad bug indeed. Could you please file it on trac ?
If you feel like getting your hands dirtier you could also
look at providing a patch for the testcases:
topology/test/regress/st_remedgemodface.sql
topology/test/regress/st_remedgenewface.sql
I'm assuming ST_RemEdgeNewFace is also affected, surely
worth adding a testcase for it as well, no matter if it
is currently affected or not.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
