[postgis-users] PostGIS let me remove an edge shared by a topogeometry
Jose Carlos Martinez
jomarlla at cgf.upv.es
Wed Apr 11 01:57:57 PDT 2012
Hi Sandro, thanx for the detailed answer.
The query returns 0 rows:
s6=# SELECT r.* FROM t3.relation r, t3.parcelas p
WHERE r.topogeo_id = id(p.topogeom)
AND r.layer_id = layer_id(p.topogeom)
AND p.gid = 2;
topogeo_id | layer_id | element_id | element_type
(0 rows)
s6=# select * from t3.relation ;
1 | 1 | 1 | 3
3 | 1 | 3 | 3
Even though the topogeometry exists:
s6=# select gid,(topogeom).* from t3.parcelas;
gid | topology_id | layer_id | id | type
1 | 30 | 1 | 1 | 3
2 | 30 | 1 | 2 | 3
3 | 30 | 1 | 3 | 3
On 11/04/2012 10:41, Sandro Santilli wrote:
> On Tue, Apr 10, 2012 at 09:50:05PM +0200, Jose Carlos Martinez Llario wrote:
>> Dear List,
>> Dont know why PostGIS let me remove an edge which is needed by a
>> topogeometry (see point c) )
>> This is a bug or it is the expected behavior?
> ST_RemEdgeModFace (which you're calling) is required to _modify_
> one face to take up the space previously occupied by the faces this
> edge was separating.
> By convention, when one of the faces is the universal face, the
> _other_ face is kept, while if both faces are not universal, the
> face on the _right_ is kept and the face on the _left_ is remved.
> Now, if you have a TopoGeometry defined by only the face that is
> removed you get an exception, while if you have a TopoGeometry
> defined by the face that is modified, or by both faces, you get
> no exception.
> At least this is the current intended behavior.
> Not sure if it makes sense.
>> b) when I try to remove an edge which is needed by a topogeometry
>> but one of the side is the universal polygon (id 0) PostGIS does not
>> throw an error:
>> s6=# select ST_RemEdgeModFace ('t3', 6);
>> NOTICE: Updating next_{right,left}_face of ring edges...
>> NOTICE: Deletion of edge 6 joins faces 2 and 0
>> st_remedgemodface
>> 0
> Given the above intended behavior this does indedd sound like a bug.
>> c) The topogeometry is an multiopolygon empty
>> s6=# select st_astext(topogeom::geometry) from t3.parcelas where gid = 2;
>> st_astext
>> MULTIPOLYGON EMPTY
> I guess the topogeometry is now defined by face 0 ?
> Try something like:
> AND p.gid = 2;
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
