[postgis-users] How to design a database for continents, countries, regions, cities and POIs?
Jerry Carter
jerry at jerrycarter.org
Wed Apr 11 08:55:41 PDT 2012
Thanks for the quick answer. Just read your writeup on the subject [1]. This looks like a _very nice_ addition and should be extremely helpful. I've got some experimenting to do!
-=- Jerry
[1] http://strk.keybit.net/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf
In otherwords, you skip
On Apr 11, 2012, at 11:51 AM, Sandro Santilli wrote:
> On Wed, Apr 11, 2012 at 11:47:02AM -0400, Jerry Carter wrote:
>> I might have a geometry for a country and separate geometries for the
>> next layer of administrative regions (e.g. states in the United States).
>> But there are often minor differences in the polygons such that the
>> polygon for the country is nearly but not exactly the union of the states.
>> How is this handled?
> In the topology model your higher layer will be defined by composition
> of lower layer items. So you would only say that "United States" is
> formed by all the countries. And for each country you would only list
> the counties they are formed of. And for each county the parcels.
> And for each parcel the primitive faces. And each face is defined by
> its edges.
> The only actual geometries involved in all of the above would be
> the edge geometries. Not any other geometry. So there's no difference
> because primitive elements are singletons.
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
