[postgis-users] A question on ST_RemEdgeModFace usability
Jose Carlos Martinez Llario jomarlla at cgf.upv.es
Thu Apr 12 13:54:45 PDT 2012
I think your questions are related with a previous post today about
synchronizing topogeometries.
In fact, for editing topogeometries without using primitive commands I
was thinking in:
1.- Delete the topogeometry
2.- Remove the primitives which depend just on the geometry deleted.
3.- With totopogeom insert again the whole geometry
I know this procedure is not optimized at all but maybe this way (with a
new function which does this work)  one can avoid the complicated task
about using primitive editing commands and to edit the relation table
manually.
I have the feeling I not taking into account many things though.
What do you think about this procedure Sandro?
On 12/04/2012 22:43, Andrea Peri wrote:
> Hi, strk,
> thx for explaination.
> >> Is this allowed ?
> >I'm redrawing the schema for simplification.
> >You ask:
> >assuming there's a TopoGeometry T1 defined by F1,
> >is the following editing allowed ?
> > | F1 e F2 |  =>  |    F1   |
> >No, because doing so would change the shape of T1.
> >--strk;
> So, I guess, if I have a topology constraint by a topogeometry layer.
> This is a really big question, because I understand that if I put a
> topogeometry over a topology I lock (practically) the topology.
> Infact I have quite few choice to editing it if I have put a
> TopoGeometry on it.
> Perhaps
> I could try this option ?
> Always with a TopoGeometry applied over it.
> Topogeometry T1 on Face F1.
> First change edge from this
> (moving the external edge of F2 and moving also the edge "e")
> I guess the ST_ChangeEdge should allow me move the edge "e".
>  | F1 e F2 |  =>  |    F1   e  F2 |
> and after this remove the external edge of F2
>  => |    F1   e
> Is this allowed ?
> Andrea
> Andrea Peri
> qwerty àèìòù
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120412/02fd2b03/attachment.html>
