[postgis-users] A question on ST_RemEdgeModFace usability
Jose Carlos Martinez Llario
jomarlla at cgf.upv.es
Thu Apr 12 14:23:39 PDT 2012
Just to add that for a normal user to think in primitives is going to be
kind of difficult. To try to delete an edge or change a topogeometry can
be very tricky.
My opinion is that a user should work with topogeometries as if they
were normal geometries. PostGIS in a transparent way should deal with
the primitives. I know Im asking too much. Not for now. I already happy
a lot with persistent topology as it is right now.
On 12/04/2012 23:15, Jose Carlos Martinez Llario wrote:
> On 12/04/2012 23:08, Andrea Peri wrote:
>> >I think your questions are related with a previous post today about
>> >synchronizing topogeometries.
>> >In fact, for editing topogeometries without using primitive commands I
>> >was thinking in:
>> >1.- Delete the topogeometry
>> >2.- Remove the primitives which depend just on the geometry deleted.
>> >3.- With totopogeom insert again the whole geometry
>> >I know this procedure is not optimized at all but maybe this way (with a
>> >new function which does this work) one can avoid the complicated task
>> >about using primitive editing commands and to edit the relation table
>> >manually.
>> >I have the feeling I not taking into account many things though.
>> >What do you think about this procedure Sandro?
>> Hi, I guess is not sufficient delete the single topogeometry. An edge
>> could be linked to one or two faces,
>> and also the same edge could be linked to many topogeometry.
>> Infact the topogeometry not necessary need to be mutually exclusive
>> to each-other ans instead are the topology edge and faces.
>> So I could have more than one topogeometry on a single edge.
>> And I should remove also every topogeometry that is linked to the
>> edge I would remove.
> Thats why I said to remove just the primitives which depend on the
> geometry deleted (and not from any other one). This way one can clean
> the primitives which are not shared by any other geometry. Its like
> the garbage collector Sandro said before.
> After that one can insert again the whole modified geometry.
> Dont know if I could explain myself.
>> So I could have, for example:
>> on this sample:
>> / | \ (universe Face)
>> | F1 | F2 |
>> | e1 e2
>> | F3 |
>> A topogeometry T1 = F1 + F3
>> another topogeometry T2 = F2 + F3
>> and another again T3 = F2
>> and again a topogeometry T4 = F1
>> so if I plan to remove the edge "e1" I should save all four topogeometry and re-apply them after.
>> Andrea Peri
>> qwerty àèìòù
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120412/4110aa79/attachment.html>
