[postgis-users] A question on ST_RemEdgeModFace usability
Jose Carlos Martinez Llario jomarlla at cgf.upv.es
Thu Apr 12 14:48:32 PDT 2012
On 12/04/2012 23:31, Andrea Peri wrote:
> >Thats why I said to remove just the primitives which depend on the
> >geometry deleted (and not from any other one). This way one can clean
> >the primitives which are not shared by any other geometry. Its like the
> >garbage collector Sandro said before.
> >After that one can insert again the whole modified geometry.
> >Dont know if I could explain myself.
> Sorry, but I'm not sure to understand
> So I try to do an example.
> Suppose to have this topology and every topogeometry is coincident
> with a single face
>     +----e1-------+----e2-------+----e3-------+
>     |    F1       |    F2       |     F3      |
>     e13          e14           e15           e16
>     +-----e4------+----e5-------+-----e6------+
>     |     F4      |     F5      |     F6      |
>    e17           e18           e19           e20
>     +-----e7------+-----e8------+-----e9------+
>     |     F9      |     F8      |     F7      |
>    e21           e22           e23           e24
>     +-----e10-----+-----e11-----+-----e12-----+
> topogeometry T1 = face F1
> T2 = F2
> and so on..
> If I suppose to whan remove the edge e19.
> That edge I plan to remove is boundary between the F5 and F6 and so
> the edge e19 is boundary on
> Topogeometry T5 and topogeometry T6.
> You suppose to remove temporary the topogeometry T5 and T6 right ?
> After this use the ST_RemEdgeModFace to remove the edge "e19" and
> after this reapply the two topogeometry
> T5 and T6 using the totopogeo ?
> I fear that the totopogeom will re.create the edge e19 calling it "e25" :(
If some edge change the id this is no problem and then you can insert a
T5 or T6 topogeometries with totopogeom that are different from the
original ones and totopogeom will recreate the primitives. Then the user
does not have to know about primitive commands as: ST_RemEdgeModFAce, etc.
Dont take my opinion if a so serious way because Im just starting with
persistent topology though.
> Andrea Peri
> qwerty àèìòù
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120412/fdee1922/attachment.html>
